Hi Mike,
Thanks for the tips !
Let's go for the vacuum !
Just a review regarding the fans... We really do like the functionnalities of the Ultrix and the Hyperconverged philosophy. But if we need to point one fault it is the fan noise. Ultrix, Xpression as well, are very noisy. As we are in flight pack setup it is sometimes quite ennoying.
by the way thank you for your help !
Regards
Boris salhaji
EIC
France Télévisions
Sent: 10-24-2024 09:15
Subject: Autumn cleaning !
Hi Boris,
Thanks for your question.
Here is a link to a document that explains how to remove the Fan modules on an FR5. you can clean the fans once removed.
Also, if you have access to the side of the FR5 you can run a vacuum cleaner on the outside of the frame where the ventilation holes are. This will remove most of the dust.
Mike Pomerleau
