  • 1.  Aux won't send external source to Studio Monitor
    Posted 06-25-2026 05:00
    Have an interesting issue.  Currently using Ultrix frame with TDx3 in Acuity mode.  This morning, when the TD tried to send video or graphics to a monitor wall in the studio, it would not show up.  This was being done via an Aux.  If they sent a still, it worked.  Graphics and video are external sources.  To eliminate issues, our other control room does not have this issue.
    Now, all this said, the issue seems to be on the main PP ME, which is ME 3.  If we try to send a graphic to the monitor, via the aux on ME2, it works fine.  I figure a setting got changed on ME3 somewhere but not sure where to look.  Any help would be appreciated.
    Robert Kinnan
    Broadcast Engineer
    Spectrum Charter News
  • 2.  RE: Aux won't send external source to Studio Monitor
    Posted 06-25-2026 09:27
    If you use an Aux Bus (delegating the Row from a Keyer control to aux control) that should be no different between different "stripes" on the panel.
    Do you have pictures or a video you can share of delegating the two panel rows to the same aux and then showing them switching okay on the one panel row vs the other?
    It's an interesting quandary for sure.  The Aux is just a "virtual path" inside the Ultrix that will allow an output to be assigned to follow tasks.  if both panel rows are setup to control the same Aux there should be no difference in ability to send video to the outputs.
    Director, Switcher Product Management
