Sent: 10-16-2025 21:46
Subject: B2B Transition Errors
Okay so I only have one scene director for my B2B, because it's one animation. Should I have the same transition on another scene director and set that as my OUT?
You mention adding a keyframe to my OUT:
1) What type of keyframe should I add (Alpha, X, Y or Z)?
2) should I add the keyframe to an animation controller, instead of the video material?
3) Where do I place the keyframe? at the beginning or at the end of the animation controller?
4) Do I need two keyframes or is it a dummy keyframe? for example if it's an Alpha keyframe do I need one to go from 0 and a second to take it back to 100?
Alejandro Galvan
LA36 LOS ANGELES TV ACCESS
Sent: 10-16-2025 14:14
So by default, the outgoing scene is on-top in Transition logic, which means that our scene that's leaving is sticking around. We also strip all of the objects that don't have a keyframe on them in that out SceneDirector. I'm thinking all you should need to do is set a keyframe for your out-scene sponsor logo object to cut it's visibility off during the wipe animation, and you'll have the new scene's sponsor logo behind it.
Zachary Fradette
United States
Sent: 10-16-2025 00:15
Hello Simon, could I please pick your brain on transition logic? I have two issues one a bit more complicated than the other so i'll start with the "easier" one. I have a scene with back-to-back logic, but my "Cut-Point" is off. My IN/OUT out of the scene are correct, but when I perform a B2B transition, after the transition has played, I see my previous logo for a brief second, and then it cuts to the new logo. any thoughts?
SAMPLE
Excuse the phone recording, my Windows won't let me screen record with Xpression running.
Alejandro Galvan
Sent: 03-06-2024 14:21
you should have a default director that does nothing.
An IN for online and an OUt for offline.
You'll need b2b In and b2b out scene directors.
If your b2b Out takes 25 frames your in should start at 25 frames.
Obviously, these are just the basic rules and once you understand them you can break them but this is how to get started and understand it.
You also noticed a checkbox labelled render animated objects only.
When using this option ticked on, anything like a mask or an object that isn't animated will need a keyframe placed on it so that XPression renders it as part of the transition.
Follow transition logic videos 101 onwards. 103 particularly covers text if I remember correctly.
https://www.rossvideo.com/resources/ross-university/an-introduction-to-transition-logic/
