Excellent, you should only need that if you are using macros and you don't need it on every datalinq connections, I would only apply it to the main item that changes, it you turn it on on all connections it ay delay your scene going on air depending on how many.
Sent: 03-14-2025 13:04
Subject: Baseball Bug - update next batter
I checked the requery scene datalinqs on data change and that worked, thanks!
JOSHUA KEAGY
Xpression operator
Blue Ridge 11
Sent: 03-14-2025 12:07
Do you have live update turned on on the datalinq connection?
