I am not at my computer for a while but when I get back I can. I am having trouble calculating the delta as well but I will be trying the new code when I get back. I think if you are using the widget for the scores it isn't working as well. Because when I hooked up my Daktronics and controlled the score through there it started working better but still made mistakes when calculating. But as long as you have a hidden text for the Home and Away score that has the above script. Then visible text that is updated with a script in the scene director once the animation plays then it should work. The only problem is calculating the delta but storing it in another text object might work. But I can't try it at the moment. Thank you Simon for your time you have been a great help!
Sent: 01-18-2024 11:17
Subject: Basketball Score Bug Animation Scripting
Would either of you be able to upload the project file you are working on, or a different project with this script in action? I've tried implementing it into my basketball bug graphic and am having trouble calculating the delta with currentValue and previousValue.
Casey Eakins
Athletics Production Engineer - Student
University of St. Thomas
Sent: 01-16-2024 16:12
To stop them playing when they first come online you can add some control such as an if that surrounds all the other if statements.
Dim IN as xpSceneDirector
If sd.position < 5
else
<--- rest of you code here
end if
That means when it first comes online that update text will be triggered but won't do anything.
As for the other issues, you could try storing that value in a text object.
Dim currentValue, previousValue, deltaValue as xpTextObject
Dim dir as xpSceneDirector
scene.GetObjectByName("HM Score", previousValue)
scene.GetObjectByName("HM ScrText", currentValue)
scene.GetObjectByName("HM delta", deltaValue)
deltaValue.Text = currentValue.Text - previousValue.Text
engine.DebugMessage(deltaValue, 0)
If deltaValue.Text = 3
scene.GetSceneDirectorByName("HM Three Point", dir)
dir.PlayRange(0, 60)
engine.DebugMessage("3 points", 0)
else
scene.GetSceneDirectorByName("HM Point", dir)
engine.DebugMessage("less than 3 points", 0)
End If
Sent: 01-16-2024 16:00
Thank you! I checked the debug monitor and nothing is popping up when I run the script. It is kind of working now however just not correctly. When I delete the scorebug from the sequence and re-add it back in then it does the three point animation and the alternate animation at the same time. But after that no matter what I put in it does the alternate one only.
Nathaniel Rudolph
Xpression Graphics Operator
CSBN
Sent: 01-16-2024 04:19
The debug monitor I am talking about is this one.
Sent: 01-15-2024 18:34
It says that everything is complied no messages, it is green. When I increase the widget (Data source set to Counter 2) any amount on the AW ScrText it does the simple animation (AW Score) for the "else" statement but doesn't do the three point animation when I increase it by 3 (For example I type 3 into the counter when it is 0). Just to make sure this is exactly what I have:
Dim currentValue, previousValue as xpTextObject
scene.GetObjectByName("AW Score", previousValue)
scene.GetObjectByName("AW ScrText", currentValue)
Dim delta As Integer = currentValue.Text - previousValue.Text
If delta = 3
scene.GetSceneDirectorByName("AW Three Point", dir)
dir.PlayRange(0, 131)
else
scene.GetSceneDirectorByName("AW Score", dir)
End If
I have attached some images as well
Compiler on the AW ScrText (OnSetText)
The hidden text
Scene directors for the score bug (I have only done the AW one for three point right now)
Nathaniel Rudolph
CSBN
Sent: 01-15-2024 18:00
What does the debug monitor say?
Sent: 01-15-2024 17:55
For some reason it still isn't working. I copied and pasted your code into the script editor, made sure all the play ranges were correct. All the scene directors are named correctly. I am trying it with a counter widget since I don't have Daktronics up at the moment. Any ideas to why it might not be working?
Nathaniel Rudolph
CSBN
Sent: 01-15-2024 16:22
Sounds good to me.
Sent: 01-15-2024 16:20
Thank you very much for your help! I do plan to run it on the hidden text for the score (HM ScrText). Then I will have a script on the scene director to change the score (HM ScrText to HM Score). Does this still work?
Nathaniel Rudolph
CSBN
Sent: 01-15-2024 16:06
Where do you plan to run that? On the text object itself when a score is changed?
You can of course add an else to run the other scene director for different animation.
Yours looks good, mine would have probably looked like this;
If delta = 3
else
End If
Sent: 01-15-2024 15:51
Oh yes I do have that. So would this be correct? (Note that the HM Score is the visible text object on the scorebug itself, and then HM ScrText is the hidden one being updated by Daktronics then will update the HM Score after the animation)
Dim previousValue As Double
Dim currentValue As Double
Dim dir As xpSceneDirector
previousValue = scene.GetObjectByValue("HM Score", previousValue)
currentValue = scene.GetObjectByValue("HM ScrText", currentValue)
Dim delta As Double = currentValue - previousValue
If Math.Abs(delta) = 3 Then
End If
Nathaniel Rudolph
CSBN
Sent: 01-15-2024 14:57
When you do your animation you must be animating the old score off I assume?
Then the new score in?
You can pull the old score from the object you are animating out?
Sent: 01-15-2024 14:54
Thank you I updated my code but I am still not sure how to have it know what the previous score is. How would I store this?
This is what I have so far (For an increase in 3 points):
previousValue = GetPreviousScore() 'this is where I am thinking I would get it from I just don't know if there is a method for this
currentValue = GetCurrentScore()
Nathaniel Rudolph
CSBN
Sent: 01-13-2024 06:25
I would compare the old score with the new score and calculate the delta.
If the delta equals 3 then play the animation else play the other animation.
I'm traveling and writing this on the move or I'd write the code for you here.
