Apply the mask material to a quad. Default anchor is in the very center. Scale up to cover entire scene. Set x scale to zero and keyframe. Then advance your time to let's say 30 frames. Set X scale to max scale and keyframe. Mask will now squeeze out from center to both edges. Play with interpretation to have it ease in to the stop point.
Sent: 05-20-2024 13:04
Subject: Box Mask - Key Framing
Thank you Malcom for your message back. I will try what you have suggested. I know you can keyframe a mask. So as far as the Box Mask. How would you keyframe that?
Michele Lee Hampton
Graphics Operator
Hermosa Beach, CA
Sent: 05-19-2024 12:03
Hi Michele,
Two ways come to mind. Two masks, one for each of the "curtains". You could animate them easily on the X axis, or set the anchor point on the outer edge if you want to scale them instead. Second would be a mask the same size as the display. Anchor point in the center, and animate on the X scale to reveal the video. You would start with scale X = 0 and then scale out to full scale. Let me know if I'm missing the point. Have fun.
Malcolm Thorpe
xpression design
Sent: 05-19-2024 11:55
Hi Malcolm. I am thinking of using a box mask to crop a large graphic that will be playing out of Tessera. It would need to split from the very center and look like it is hiding/cropping as the screen opens up from the center then closes back up. Like drapes that you would open then close up. The graphic would have animation and not a static image. Looking to make it look like the split at the center hides/crops the graphic and not pushing it to the left and right. Does that make any sense?
Michele Lee Hampton
Graphics Operator
Hermosa Beach, CA
Sent: 05-17-2024 17:28
Short answer: Yes, otherwise I would need more info.
Malcolm Thorpe
xpression design
