You need to put your parameter into a container of some kind - containers can change the layout of the components inside. We have grids, tables, tabs, border layouts, wrapping 'flow' layouts, and more. For your specific requirement, a "simplegrid" with 6 columns makes the most sense:
<meta>
<params>
<param access="1" constrainttype="INT_CHOICE" name="ButtonPick" oid="ButtonPick" precision="0" type="INT32" value="1">
<constraint key="1">1</constraint>
<constraint key="2">2</constraint>
<constraint key="3">3</constraint>
<constraint key="4">4</constraint>
<constraint key="5">5</constraint>
<constraint key="6">6</constraint>
<constraint key="7">7</constraint>
<constraint key="8">8</constraint>
<constraint key="9">9</constraint>
<constraint key="10">10</constraint>
<constraint key="11">11</constraint>
<constraint key="12">12</constraint>
</param>
</params>
</meta>
<simplegrid cols="6" height="100" left="1317" top="83" width="435">
<param expand="true" oid="ButtonPick" style="style:toggleButton;" widget="radio-toggle"/>
</simplegrid>
James Peltzer
