ok. thanks for the help.
Sent: 03-07-2023 07:36
Subject: C# app wiht datalinq method for Xpression
async/await does not handle errors. It just lets your program to do stuff in the background, allowing the main program to keep going. It's probably not even necessary here since writing to a file should not take much time. If you want to handle errors, you need use exception handling.
try{ File.WriteAllText(@"D:\path.json", JsonSerializer.Serialize(_data));}catch (Exception e){ // If this code is reached, an error has occurred.}
JohnCorigliano
Senior Software Engineer
ISC
Sent: 03-06-2023 13:28
I'm glad you brought that up. I think I'm going to give that a try with json. I found this post on stackoverflow, and maybe you can give me some advice here. I thought it might be a good idea to use the following technique to avoid locking up my app while serializing/reading/writing the file. Still, I'm thinking that the IOException could be the problem I'm worried about from Datalinq reading while I'm trying to write. Do I need to be concerned about this or will "await" avoid this exception?
using System.Text.Json;using System.Text.Json.Serialization;List<data> _data = new List<data>();_data.Add(new data(){ Id = 1, SSN = 2, Message = "A Message"});await using FileStream createStream = File.Create(@"D:\path.json");await JsonSerializer.SerializeAsync(createStream, _data);
Roger Heyward
Sent: 03-03-2023 10:25
We've been using this method for a few years now - except we write JSON files, not XML, but the principal is the same. We write to these files as often as once every 10 seconds (occasionally faster) and collisions with Datalinq reading the file as we are writing them are rare. In the event of a collision, we just wait 1 second and try again and repeat this x number of times.
We are currently visiting the idea of changing the way we do things because of some issues we have had with Datalinq. Nothing major, Datalinq works fine, but we are now considering writing the data directly to the fields on the graphics to give us more control over things.
There are pros and cons to each method, so you will probably have to compromise at some point.
JohnCorigliano
ISC
