Hi Steve,
Thank you for providing this information. I see you have explained the behaviour you are seeing as "As long as I open Dashboard, did nothing else and attempted to move the camera with the virtual joystick (or the physical joystick on the console), I was fine. As soon as i selected a preset, when I went back to the joystick, chaos again ensued."
Unfortunately the only solution I can offer you is to ensure you have selected the appropriate camera protocol in Dashboard. PivotCam-SE should be selected from the drop down. These camera's had very fast panning/tilting and joystick control which is why we moved to the PTZ 12G.
I am sorry I could not be of more help.
Tim Beland
Field Services Specialist
Ottawa Canada
Sent: 11-08-2024 14:40
Subject: Camera Movement on PivotCam
1. Dashboard version is 9.10.1.
2. The physical joystick I was referring to is the one on the control surface of the switcher we have: Ross Carbonite Black Solo 13. The virtual joystick I was mentioning is on a widget of a custom panel I built in Dashboard. (see attached screen shot)
3. No we select presets from the same custom Dashboard panel I mentioned. (again, see attached screen shot)
Steve Witwicki
Video Technical Director
Light of Christ Church
Sent: 11-05-2024 15:18
Hi Steve,
Thank you for your message. You are correct that PivotCams are no longer supported, but I would still like to see if there is anything we can do to help you out.
I have a few questions to help me better understand what you are experiencing:
- What version of Dashboard are you currently using?
- Is the joystick you are using a Ross Robotics model?
- Are you utilizing Ross SmartShell software to select presets?
If you are using SmartShell, could you please confirm the version you have? The version number can be found in the top left corner of the user interface.
Thank you.
Tim Beland
Canada
