I am trying to figure out how I can somehow trigger an Aux bus to change to a specific source only when a specific keyer is active on the PGM bus of the switcher. The use case is to try and have an output of the switcher with embedded audio for a CG channel only when the keyer is on-air.
I can see where I can point the Aux to follow what the source of M3K3v is, but the audio is present all the time. I'm trying to create a safety net for the A1 to not have to track the CG channel on and off and protect against hearing a graphic playout when it's not on air.
Thoughts?
Andy
