  • 1.  Carbonite effects and passing captions
    Posted 05-04-2026 18:22
    If my users are doing a multi-box effect, which video source will provide the captions for the stream?  Can I configure that so a specific box provides the captions if available?
    David Knighton
    Engineer
    NCSC
  • 2.  RE: Carbonite effects and passing captions
    Posted 05-04-2026 18:41
    Anciliary Data source is from the BKGD bus of the ME.
    Director, Switcher Product Management
  • 3.  RE: Carbonite effects and passing captions
    Posted 07-02-2026 09:37
    Les,
    if using the P/P bus, the system should pass Ancillary Data from the PGM bus, correct?  We're not seeing that here at the moment and it's a bit of a problem for us.
    David Knighton
    Engineer
    NCSC
  • 4.  RE: Carbonite effects and passing captions
    Posted 07-02-2026 10:15
    The Source on the BKGD Bus of the ME is what should be showing up on the output of the ME.
    There is a setting in the Config / System / Global for setting pass or Strip of Anc Data.
    Note any FSFC that is assigned to an input is going to Strip the ANC Data and that includes the CC.
