There is a limitation when in an Interlaced Mode and having to scale down and de-interlace. It's not possible to offer that.
However ... you could run in 1080p59.94 and convert all inputs to 3G :) and then down convert to 720p on the output..
Sent: 04-23-2023 07:13
Subject: Carbonite Multiview in 720p is soft not sharp like 1080
10-4 Thank you. Turns out the TV up conversion was great for 1080i but very poor for 720. A side question. Is there a reason you cannot down convert one of the outs from 1080i to 720p? Or is there a workaround besides standalone gear?
Sent: 4/20/2023 7:23:00 PM
Subject: RE: Carbonite Multiview in 720p is soft not sharp like 1080
The MV is operating in the same Format as the switcher. So When you are in 720p operation the output of the MV is 720p and thus the Monitor is upconverting 720p to 4K resolution on the monitor.
