  • 1.  Carbonite panel cut button failing
    Posted 09-30-2022 04:26
    The cut button on our Carbonite panel is failing - are spares available anywhere? Quite happy to replace it if I can source the correct button.
    Thanks,
    Andrew.
    Andrew Shilcock
    Engineer
    Hochanda Global
  • 2.  RE: Carbonite panel cut button failing
    Posted 09-30-2022 09:00
    You need to contact techsupport about ordering Parts.  Phone, email and ticket system can be found here:
  • 3.  RE: Carbonite panel cut button failing
    Posted 09-30-2022 09:26
    Thanks, I have put in a ticket. I had just wondered if it were something that could be purchased off the shelf.
    Andrew Shilcock
    Engineer
    Hochanda Global
