You can start with these instructions -- Graphite / Carbonite / Ultrix Carbonite it all works the same.
-You setup IDs in Destinations of Ultrix that feed the inputs of the switcher. You set these outputs to "routed" as the type (Normal is default)
-You setup a TSL Connection to the switcher to send that data. (TSL in the switcher is always running in TCP Server mode - STATUS page shows the PORTs)
-In the Switcher inputs you assign the Input to the TSL ID of the output feeding the Input and set it to use NAME ONLY (that was it is internally calculating tally not looking for a TSI 4000 to be telling it when it is on air..)
-In the switcher you setup a TSL Send Device to the Ultrix in the Devices Menu (see Ultrix Connections tab for the ports to use)
-In the Ultrix you also assign an ID number to the Sources (I usually just start at 1 from the top since it will be "routed" back when the switcher inputs are on air to switch to the ID for what is on that output to tally in the MV.
Here is a doc that has visuals. It is older so if you are now on Ultrix Version 6 it will look different .. at some point we will get back to making this current again.
