We've recently purchased a Carbonite Ultra 60 and are currently operating it in UHD. Our setup includes a mix of 12G and 3G video sources, with the 3G sources being upconverted at the input stage of the Carbonite.
We've encountered an issue where applying input conversion to the 3G sources causes the video to shift slightly to the right, resulting in a thin black vertical line on the left side of the image.
Additionally, when cutting between a native 12G source (which is in sync) and an upconverted 3G source, there's a noticeable jump between the two signals, suggesting a mismatch in timing or processing delay.
The Carbonite is genlocked to our SPG via a 1080p50 reference. We also tested with 1080i50, but the issue persists.
We've found that enabling frame sync on the 12G signal fixes the jump, but the small black line on the left side remains visible on 3G input and now also 12G input.
Has anyone else experienced this issue or found a workaround?
Any insights would be greatly appreciated.
Marius Hasler
