Hi Brian,
A way to accomplish this is to build a DashBoard custom panel. The panel will track the ME PGM bus, and when Cam 1 or Cam 2 is on, it will put Cam 1 or 2 respectively on the miniME1's key. Otherwise, it will not do anything.
I do not know how familiar you are with building custom panels on DashBoard. I have attached a screenshot of the visual blocks to make this work. If you need more guidance, let me know.
*Note that you will need the custom panel open for this to work.
Aaron
