Hi Vakhtang,
Perhaps there is some confusion. Carbonite Ultra 60 does not have 6MEs. In HD, it has up to 3MEs (6 keys per ME) with 4 miniMEs (2 keys per ME).
But your understanding of shared DVEs is correct. If you use more DVEs on one ME, there are less DVEs for other MEs/miniMEs.
Aaron
Sent: 04-22-2025 07:49
Subject: Carbonite ultra 60 MEs keyers specs
Thank you Luis for your quick response.
Just to confirm: although each ME on the Carbonite Ultra 60 can use up to 6 2D DVE effects, the system has a total of 12 shared DVEs. This means that if I'm using all 6 MEs at the same time, I can expect to have approximately 2 resizable windows (DVE effects) available per ME - unless I allocate more DVEs to certain MEs and fewer to others. Is that correct?
Vakhtang Peradze
Sent: 04-22-2025 07:03
On a 6 keyer ME you can have 6 2D DVE effects but remember on the switcher you have a total 12 Sharable 2D DVE's . So if one ME has 6 boxes that leaves you with 6 left over to share.
Louis Santiago
Project Manager -Professional Services, North America
Ross Video | Let's make it real
M: +1 (719) 367-2240
Visit us at rossvideo.com
| Sent using my phone, please forgive any typos. |
