Hi Andrew,
I had a quick look at the ETC ColorSource user manual and it does not appear that it supports RossTalk or any plain text protocol. You may want to reach out to ETC Support to confirm this.
However, there are other ways to accomplish what you want to achieve.
- OSC protocol is mentioned in the ColourSource AV User Manual. Sending OSC is supported by Ross Video's DashBoard. So DashBoard can be the gateway between your Carbonite and the ETC ColorSource. Carbonite sends RossTalk to a custom DashBoard panel which in turn sends OSC to the ColorSource.
- Alternatively, Bitfocus Companion supports OSC. So Companion can be the gateway between your Carbonite and ColourSource.
I hope one of the above methods works for you.
Aaron
