I am seeing this as well ... I will have them look at it.
I don't see the thumbnail update with the correct clip .. but the Time Duration and Bar is updating..
PS you can click on the progress bar to jump to a point with the content viewable and then press the Capture Thumbnail to generate a thumbnail for you.
Sent: 04-03-2024 19:28
Subject: Carbonite Ultra Clip Store capacity
Yet another question:
I noticed that when cueing clips in Clip Player via Custom Control, the player in Dashboard doesn't update. The clip cues, but the player stays empty. You can't really confirm that you have the right clip loaded.
Feature? Bug?
San Francisco United States
Sent: 04-03-2024 13:18
Thank you. And no ... after many trips to NAB, I'm done! I know how much work goes into it for companies like Ross. Good luck! :)
Sent: 04-03-2024 07:23
Hi Danny, you are correct, the capacity of the USB dictates max lengths. If your heading to NAB I would be happy to give you a 'refresher' on the nuances of the Chroma key. Of course Les can do the same. :)
Nigel Spratling
