Trying to upgrade our Carbonite Ultra from v3.0 to v7.1. I don't see any documentation about a recommended upgrade path, so I assume it's okay to leap directly to 7.1?
We tried upgrading through Dashboard by drag-and-dropping the *.ultra file, but the upgrade failed (I checked that dip switch 4 is in the up position).
I'll try upgrading directly from the USB port on the unit next, but I cannot find any instructions on how to do this in the literature. I assume I just put the upgrade file in the root directory of a USB drive, connect it to the frame, and press the upgrade switch on the front panel?
Vincent Costa
System Support Engineer
Nouvelle Medias
