if you have available inputs on the Ultra ... and a Framesync on the ultra you could Loop video back into it -- use the Frame Sync Delay mode and add some frames of delay with it then output again from the switcher to the destination that needs delay.
Sent: 02-12-2025 13:07
Subject: Carbonite Ultra Video / Audio Sync.
Thank you Les, Any recommendations on the best way (Hardware) to do that?
Erik Gann
Technical Director
Lighthouse Church
Sent: 02-12-2025 12:38
You are going to need to add delay then after the switcher but before the destination(s) that require it to match up the audio delay.
Sent: 02-12-2025 12:31
Hey thank you so much for the reply. The video is ahead of the audio. Where would i apply the delay for that?
Erik Gann
Technical Director
Lighthouse Church
Sent: 02-12-2025 12:12
Anything in a Frame Sync will have 1 Frame of delay applied to that source. However the Camera Chain it's self could have inherent delay -- ie a Mic to a console to a speaker looking at a Camera through a switcher could see that the audio is out of sync because from lens to sensor to output could be 3 or 5 frames...
Switcher it's self is less than 1 line of video processing delay ( except for a source in a FS which has 1 frame of delay or a Source inside a DVE which has 1 frame of delay).
You first need to figure out which way is your delay issue --- is the Audio Ahead of the Video or is the Video ahead of the audio. Then apply the delay in the correct place to get them in sync.
with multiple destinations / paths and processing this may require different solutions for each.
