Yes go to the Configuration Menu - Inputs and then change the Carbonite Mnemonics -- those allow you to set the Colour and the Font Size. That is what the virtual panel will use as well.
Sent: 11-19-2025 13:51
Subject: Carbonite Virtual Panel
Hi Les - Once you've setup the Bus Map for a virtual panel, is there a way to change the source names that appear above the buttons so they aren't all just two letters?
Eric Garabrant
Studio Engineer
COok Medical
Sent: 05-28-2025 10:54
Hi Bert,
The Virtual Panel has it's own Personality and Bus Map settings. Also has it's own "menu" hence running on a separate port from the physical panel.
You have to build it's own Bus Map. -- Menu - Personality - Bus Map
Sent: 05-28-2025 04:13
Hi Aaron,
the virtual Panel is a good possibility if the hardware panel fails. I tried it, but the buttons at the virtual panel are not the same as on our hardware panel.
We use Carbonite Ultra with actuall software version. Where and how can i edit the buttons at the virtual panel ?
Regards,
Bert
Bert May-Hoppe
Broadcast Engineer
WDR
Sent: 03-04-2024 22:22
Hi Danny,
This will depend on which Carbonite frame you have, and the version of the firmware running on it. The Virtual Panel used to share the same port as the other Carbonite menus in DashBoard, but was separated to its own port (5257) in later firmwares.
Assuming you have a Carbonite with newer firmware, you will need the IP address of the Carbonite frame.
- Click the '+' icon to add a new device.
- Select TCP/IP DashBoard Connect or openGear Device.
- Enter the IP address of the Carbonite frame, give it any name you desire, type in port 5257.
The Virtual Panel will appear in your DashBoard tree. Give it a few moments to load.
Aaron
