I now have a script and timeline, which keeps running in a loop, until all the values have been taken. However, there is also a code for closing the current scene, so that it continues to the next scene in the carousel. Or is there something to start the next scene right away?
Sent: 01-10-2024 08:45
Subject: Carousel with single scene, but mulyiple datalinq results
Found it! Useful!
An error came up for me, but it has nothing to do with the script I'm stuck on. I'm going to do some more research.
Harm Dijkman
RTV OOST
Sent: 01-10-2024 08:07
This one that will tell you errors with your script, it's pretty much impossible to script correctly without it.
Sent: 01-10-2024 07:50
i'm only using the live log. Is this what you meant?
Harm Dijkman
RTV OOST
Sent: 01-10-2024 07:46
Are you using the debug monitor?
Sent: 01-10-2024 07:44
I have a scene with a timeline in which the first part is general information. This is transferred to the first block of information, after which the counter is added up at the end and it is checked whether the next value exists. If it can be extracted from datalinq then it goes back to frame 30 with the new values.the only thing I can't check is the value of my 'Keys'. Maybe that counter doesn't work.
So maybe the question is more: how do I check this counter during online? And do you see any other rarities
hereby my file for more information
https://we.tl/t-Sqkw9p4Jcb?
Harm Dijkman
RTV OOST
Sent: 01-10-2024 06:08
do you have all the required objects for this script to work?
Do you use debug monitor?
Sent: 01-10-2024 05:39
I found out that you can place a script within 1 scene (on a timeline) where you can have a relID check if there are multiple results that can be displayed. You can then call it up by restarting the timeline and increasing the relid by 1 and refreshing the values of the datalinq, but with the code below nothing happens to me. And I think it's true. Am I missing something?
//Row is the actual number, checkrow is row incremented with one, to check is this value excist.
dim keys as xpDatalinqKeys
dim key, checkey as xpDatalinqKey
dim checknext as xpTextObject
dim Controle as xpTextObject
dim curTakeItem, nextTakeItem as xpTakeItem
dim seqGrp as xpTakeItemGroup
Dim outFB as xpoutputframebuffer
Dim text2 as xpTextObject
Engine.getoutputframebuffer(0, outFB)
outFB.GetTakeItemOnLayer(0,curTakeItem)
curTakeItem.GetGroup(seqGrp)
Scene.GetDatalinqKeys(keys)
//counter
keys.GetKeyByName("ROW", key)
keys.GetKeyByName("CHECKROW", checkey)
//values from datalinq
Scene.GetObjectByName("MESSAGE",Controle)
Scene.GetObjectByName("CHECK",checknext)
//Checks next row.
if not checknext.Text = Controle.Text then
seqGrp.Pause
key.AsString = (CINT(key.asString) + 1)
checkey.AsString = (CINT(checkey.asString) + 1)
scene.RefreshDatalinqs
engine.DebugMessage("increment",0)
else
seqGrp.Resume
scene.SceneDirector.stop
end if
Harm Dijkman
RTV OOST
