Sent: 04-14-2023 18:40
Subject: Change constraint button colors
One more try - the original example also was still referencing the toggle button defined style and this was overriding the custom colors. When I remove the style="style:toggleButton" attribute, it works for me.
James Peltzer
Sent: 04-14-2023 17:26
@James Peltzer It is still not changing the button color (or any attributes for that matter)
Chris Schaaf
Sent: 04-14-2023 16:55
Hi Chris
Sorry about that - I did the example quickly and without having access to a Carbonite to verify against. In my haste, I missed a semicolon between the 2 style attributes. This is what the <param/> should look like (I have also updated the example above to correct the issue):
<param constrainttype="INT_CHOICE" expand="true" height="60" mid="48252" oid="0xF97" precision="0" width="101"> <constraint key="1010">GLD CLN<f:bg#0000FF;t:bg#FF0000></constraint> <constraint key="1011">SLR CLN<f:bg#00FF00;t:bg#FFFF00></constraint> <constraint key="1018">CG1</constraint> <constraint key="1020">CG2</constraint> <constraint key="1022">CLIPS</constraint> <constraint key="0">BK</constraint> <constraint key="11000">PGM</constraint> <constraint key="11001">PRV</constraint> <constraint key="11100">ME 1</constraint> <constraint key="11101">ME1PV</constraint> <constraint key="11200">ME 2</constraint> <constraint key="11201">ME2PV</constraint> <constraint key="25000">MinME1</constraint> <constraint key="25100">MinME2</constraint> <constraint key="25200">MinME3</constraint> <constraint key="25300">MinME4</constraint> </param>
James Peltzer
Sent: 04-13-2023 14:03
@James Peltzer I added the style data as you had above and it didn't do anything. It didn't case errors, but it didn't change the color either. Am I possibly missing something?
Chris Schaaf
Sent: 04-13-2023 07:26
Hi Chris
Your easiest path is to embed the color information into each entry. You can do this by adding style data at the end of the text inside of "<"...">".
<abs name="MiniME1" virtualheight="164" virtualwidth="928"> <simplegrid contexttype="opengear" height="138" left="15" objectid="Carbonite 00:0F:9B:04:08:29<br>Slot 0<br>Carbonite" objecttype="Carbonite" rows="1" top="14" width="903"> <simplegrid baseurl="http://10.4.10.103/tmp/busestab.xml" cols="12" contexttype="opengear" ipaddress="10.4.10.103:5253" objectid="Carbonite 00:0F:9B:04:08:29<br>Slot 0<br>Carbonite" objecttype="Carbonite" rows="0" subscriptions="false"> <param constrainttype="INT_CHOICE" expand="true" height="60" mid="48252" oid="0xF97" precision="0" style="style:toggleButton;" width="101"> <constraint key="1010">GLD CLN<f:bg#0000FFt:bg#FF0000></constraint> <constraint key="1011">SLR CLN<f:bg#00FF00t:bg#FFFF00></constraint> <constraint key="1018">CG1</constraint> <constraint key="1020">CG2</constraint> <constraint key="1022">CLIPS</constraint> <constraint key="0">BK</constraint> <constraint key="11000">PGM</constraint> <constraint key="11001">PRV</constraint> <constraint key="11100">ME 1</constraint> <constraint key="11101">ME1PV</constraint> <constraint key="11200">ME 2</constraint> <constraint key="11201">ME2PV</constraint> <constraint key="25000">MinME1</constraint> <constraint key="25100">MinME2</constraint> <constraint key="25200">MinME3</constraint> <constraint key="25300">MinME4</constraint> </param> </simplegrid> </simplegrid> </abs>
James Peltzer
