You can also use {M:Material Name} such as {M:Blue} to apply a material instead of making separate fonts.
This way you just have 1 white font and can switch face materials instead.
So you could have same as Roma but instead of
txt.Text = "{1}" + txt.Text '{1} - green font ID
you could have
txt.Text = "{M:Green} + text.Text
Sent: 08-29-2022 04:04
Subject: Change font color in XPN 10
Hey!
Try another method.
First: Create three fonts: green, red and blue (blue if the price does not change)
Second: Set the script to "OnOnline" and "OnPreviewRender".Dim up, down As xpBaseObjectself.GetObjectByName("Up", up)self.GetObjectByName("Down", down)Dim txt As xpTextObjectself.GetObjectByName("Text1", txt)If up.Visible Then txt.Text = "{1}" + txt.Text '{1} - green font IDElseIf down.Visible Then txt.Text = "{2}" + txt.Text '{2} - red font IDElse txt.Text = "{3}" + txt.Text '{3} - nochange font IDEnd If
Roman Yaroshenko
chief specialist
RBC-TV
Moscow Russian Federation
Sent: 08-26-2022 14:54
Hey,
Probably the simplest way is visual logic.
In my example based on if the quad is visible or not the material changes.
