Ah, I see. Yeah that makes sense. Thank you very much for looking into it!
Sent: 11-15-2023 07:52
Subject: Change graphic duration from the Xpression sequencer
Looking into Singualr they only have preset animations that you can adjust the curves and times on so it's much simpler for them to have this timer feature versus XPression which has completely customizable keyframe animations.
Not to say we shouldn't consider something along these lines, just that its simpler when you only have presets.
Sent: 11-15-2023 06:33
Hmmm, yeah that is a good point, I am curious now as to how that function works in other graphics software. We just recently made the switch to Xpression from Singular.live, and they have a "timer" field on their sequencer side, which adjusts the overall duration of the graphic, (https://www.youtube.com/watch?v=FzByiPdKZ6g) so I'm wondering if they are just adding frames in the middle? Or maybe have it set up so that it ignores the transitions somehow?
Jonah Applegarth
Graphics Operator
Straight Arrow News
Sent: 11-14-2023 09:12
I can see how this could be an option as long as you were using Transition Logic otherwise it would be hard to determine where exactly the extra frames should be added or taken away from.
Sent: 11-14-2023 08:45
Thank you all for the suggestions! I figured there would be a way to accomplish this through scripting or VL, and the group thing might work, it just seems a bit cumbersome when a simple "drag to adjust clip duration" feature would be much faster and easier, especially for an operator who needs to adjust the timing for individual graphics on the fly.
Jonah Applegarth
Graphics Operator
Straight Arrow News
Sent: 11-13-2023 05:02
what about group timed advance manually?
Sent: 11-11-2023 05:17
I just red you want to manualy continue - in my suggestion you have different groups and sometimes you want the rundown all in one group together. The one thing that would be great some day is groups within groups. Then a way for that is too script it. Yes with a hidden text what is published where you give in the frames etc. and then you can set the position off the offline via script or proppably some other ways. What I once did was a very siple way - I had times that been known in advance like 5 options 1 sec /2 sec... there I just put the offline on different tracks and turned via script the tracks on and off - so many different ways there. But maybe somebody else has something super simple there in mind - sometimes you do not see the forest with all that trees in the way. Greetings Nicole
Nicole Schindeldecker
FERNSEHGRAFIK
