Sent: 02-06-2024 06:48
Subject: Change Preview on Sequencer
This native option works on the local preview but (as far as I know) not on the hardware preview render output.
Here's a script that gives the operator in the sequencer the option to choose a preview frame on the hardware preview output:
![](https://higherlogicdownload.s3.amazonaws.com/ROSSVIDEO/MessageImages/19b6c4ca762e4ff299344fe468254be8.png)
The above script goes in the "OnPreviewRender" section as you can see.
The only thing is, that it seems to be necessary to have more than one SceneDirector to work on every system. There has to be nothing going on in the extra SceneDirector. The second one just has to be there. If you already have more than one SD, you don't have to add an extra one ;-).
Rob van Rooyen
Senior Graphics Specialis
NEP The Netherlands
Hilversum Netherlands
Sent: 02-05-2024 18:04
If you are running XPression version 11.0+ animated previews (with pauses) is a native feature.
![](https://higherlogicdownload.s3.amazonaws.com/ROSSVIDEO/MessageImages/a2b3bb304b154b4d90bed927c2ec57a3.png)
Sent: 02-05-2024 14:29
I would like to make it possible for an operator to select positions in an animation to use as the preview in the sequencer. I want them to be able to see what the animation will look like at different places in the timeline given their text and image selections. There are 4 different places I would like to do that.
Any help is much appreciated!
Here is my script so far:
dim sd as xpSceneDirector
dim theSELECTON as xpTextObject
dim currPV as long
self.GetSceneDirectorByName("SceneDirector1",sd)
self.GetObjectByName("PREVIEW PICTURE:",theSELECTON)
select case theSELECTON.Text
case "1"
currPV = 500
case "2"
currPV = 770
case "3"
currPV = 1040
case "4"
currPV = 1340
case else
currPV = 220
end select
'THIS IS WHERE I THINK I NEED TO SET THE PREVIEW, BASED ON THE SCENE DIRECTOR (sd) AND THE FRAME (currPV)
'MY ATTEMPTS HAVE FAILED. ANY IDEAS?
Kraig
