Hello the community, one of our client needs to be able to change his busmap quickly depending of his session type. It would be to affect cam 1 to button 1 or blank the button.
I don't think this is possible with a custom,control or a memory (correct me if i'm wrong). Would it be possible using a set without power cycling it ? If so, is it possible to load a set vith a CC or memory ?
Or do you know any trick to do this ? I could busmap auxes and change source in that aux but i need also to blank the button so that's not the way i guess.
Jerome Goncalves
Video Manager
Oculus Prime
