Thank you so much, Simon. This was very helpful. It allows me to run the game in one place in my Excel database.
If anyone else has a similar problem:
Right-click in the selected cells, format cells, select custom categories, and in the Type field, enter: 0;-0;"" (zeros will no longer be active).
Tom Jan
editor
Sent: 07-16-2025 15:05
Subject: Changing the value 0 (zero) from the Excel > Datalinq database to an invisible or preferably empty text object.
Can you set it to a space or maybe a special character?
If you set it to a special character, you can use a replace script or replace block in visual logic to set it to ""
