1 -- You need to select a UHD Mode from the Config - System Menu. I am using the Ultra 1ru system, however it would be best if you specified which Carbonite Engine you have the TD panel connected to. (in DashBoard use the Status Page and the Engine type is listed there)
https://help.rossvideo.com/ultra/Tasks/Setup/Resources/SwitcherMode.html
The switcher operates in UHD like it operates in HD so there is no special workflow or settings that change.
2. This is going to depend on Which Switcher Model you are using as to what the resource allocations will be.
Carbonite Ultra:
https://help.rossvideo.com/ultra/Topics/Setup/Video/UHD-Mode.html
Ultrix Carbonite:
https://help.rossvideo.com/ultrix-carbonite/Topics/Setup/Video/UHD-Mode.html
Carbonite Ultra60:
https://help.rossvideo.com/ultra-60/Topics/Setup/Video/UHD-Mode.html
