Hi Hylke
You are on the right path. You have done most of the steps below.
To talk to the NK-GPI you will need to connect the NK-GPI to an NK-IPS (not an NK-NET as the NK-NET does not provide power) to allow the Ultrix to communicate with the NK-GPI. The layout would look like this:
[NK-GPI] <-- TBUS --> [NK-IPS] <-- IP --> [Ultrix]
Then, under the Connections page of the Ultrix, under servers, add a Ross NK protocol server and point it at the IP address of the IPS on port 5000. After that, any commands sent from the NK-GPI will be sent to the Ultrix.
I think this is the part you are missing.
To configure the NK-GPI you just need to tell the GPI what commands to send when a GPI is triggered. You can set a single crosspoint or a macro (several crosspoints) and you can define which level you wish to switch on.
The User guide may help for connection (page 31) and configuration (page 55)
https://documentation.rossvideo.com/files/Manuals/Connectivity/NK/NK%20Series%20User%20Guide(9807DR-0100).pdf
Feel free to give us a call on the technical support line (or email) and we can help remotely.
Mike Pomerleau
