Dig deep.
Check visual logic to see if it is using the data to find the images.
Also check to see there is any VB that might be setting the images.
A naming convention was probably used. Follow the code and you should find the location.
Also, double check your materials and the image folder relative to your project. Images might be there.
Azathoth
Son of Cthulhu
