More info is needed, however, I think you will be needing this scripting method.
You will want to access the xpMaterial Object of your quad.
Then use the PlayRange method.
| Visual Basic |
Public Function PlayRange(
ByVal RangeStart As Long,
ByVal RangeEnd As Long ) As Boolean
This will allow you to jump to and play to a certain range of frames of a percent bar animation.
Is that the control you are looking for?
Azathoth
Son of Cthulhu
