Hey,
What I do is is make a material and set the blending to alpha mask
Add a texture shader for the image.
Then I invert the current stage modifier.
Add another standard layer and put that above the original
Place objects in a layer object to see blending.
Sent: 08-15-2022 18:12
Subject: Converting color material to white
I may have found a solution - but if anyone has something better, please post.
Structure the Image and Color like this:
And set the blending mode for "LayerObject2" to this:
The color can technically be anything - in my case I needed white.
Brian Bell
Coordinating Designer
ESPN INC.
Charlotte United States
