Yes-
1-Edit the custom panel
2-Double click anywhere in the background
3-When the Edit Window pops up click on the top left corner
4-On the right type in a port number in the internal Rosstalk GPI Listener
5-Click on apply and close
6-Double click the button you want to fire using a custom control
7-Just above the tasks window there is a Trigger ID-enter a numerical value (1,2,3 etc)
8-Once you assign a trigger id to the buttons save the panel
9-On your switcher add a ROSS Talk Device using the IP address of the PC that has the panel you want to control making sure you use the port you assigned for the GPI listener
Carbonite: https://help.rossvideo.com/carbonite-device-db/Topics/Devices/RossTalk/RossTalk.html#RossTalk
Acuity: https://help.rossvideo.com/acuity-device/Topics/Protocol/RossTalk.html
10) Once you add the device to your switcher create a custom control to trigger the button using RossTalk GPI command and the Trigger value you applied to the button. Using the RossTalk GPI command
Louis Santiago
Senior Demo & Training Solutions Specialist - Prime, Switcher
Ross Video | Let's make it real
M: +1 (719) 367-2240
Visit us at rossvideo.com
This e-mail and any attachments may contain information that is confidential to Ross Video.
If you are not the intended recipient, please notify me immediately by replying to this message. Please also delete all copies. Thank you.
