Sr. Creative Arts Director
Sent: 08-01-2024 13:23
Subject: Custom Control (Macro) Timing Adjustment
Hi Zachary,
I think I understand now - you would like to animate the transition. Yes, this is possible!
So the animation will be achieved using Memories. Then the memories can be inserted into a Custom Control if you would like the animation to be a part of a larger sequence of events.
- You will need to create 2 different memories: one with DVE param at 0%, one with DVE param at 36.2%
- Set Recall mode to Effects Dissolve; and Effects Dissolve duration to 2 seconds
- Since our focus here is the DVE key, turn on key attributes for the relevant key
- Save the 2 memories.
Now when you recall and toggle between the 2 memories, the switcher will interpolate the 2 different DVE parameters over 2 seconds.
For a better understanding of memories, look at these 2 links.
- https://www.rossvideo.com/resources/ross-university/carbonite-store-and-recall-memories/
- https://rossvideo.community/discussion/carbonite-attributes
The Carbonite U video (first link) is admittedly getting old, with an old color scheme and layout for the UI, but the concept still holds.
Aaron
Sent: 08-01-2024 12:42
Thanks for the reply, Aaron. I would love to see the transition happen live (The key shifting from left to right smoothly over 2 seconds).
Would you happen to know if that is possible?
Zachary McCrorey
Transformation Church
Sent: 08-01-2024 12:18
Hi Zachary,
May I clarify that you would like to set the DVE X-position at 0%, wait a predefined amount of time while ME2 transitions, and then set the DVE X-position at 36.2%?
To achieve this, insert a PAUSE event after the ME2 transition event.
Custom Control > Pause > Set desired duration for the pause
Aaron
