  • 1.  Custom Control to send GPI
    Posted 06-10-2026 20:40
    I am trying to create a custom control from my carbonite black plus to a custom dashboard panel that lives on my switcher.  The custom panel has buttons that trigger my Musco lighting system via a UDP string. I can trigger the Musco lighting system via the buttons that I made in the custom panel but when I try to take my custom control, the Musco system does not respond.
    Jason Sanford
    Broadcast Engineer
  • 2.  RE: Custom Control to send GPI
    Posted 06-10-2026 20:48
    Do you have the Global Listener enabled in DashBoard on your panel?
    on the Toolbar -- Window - Preferences - RossTalk GPI Listener Enable -- also set it to  7789 and then modify your device config for sending to the panel.
    TD Panels may have port 7788 reserved for the Panel to run it's rosstalk listener and best to put DashBoard on a different port .
    Then also make sure your button "trigger ID" has that GPI value in it that you are showing.  I also see two "new custom panel grid" files open.  You might want to make sure you don't have two different things running either
    Director, Switcher Product Management
  • 3.  RE: Custom Control to send GPI
    Posted 06-11-2026 11:18
    Hi Les I have the global listener enabled and I have switched to port 7789 in the global listener and in the device configuration. The trigger ID and GPI value are the same in the custom control as well as the trigger ID.
    I made these changes and the custom control still does not work. Is there any code I can add to the button to see it is being called on?
    Jason Sanford
    Broadcast Engineer
    Washington Commanders
  • 4.  RE: Custom Control to send GPI
    Posted 06-11-2026 11:22
    Please post screen shots of the device configuration for the RossTalk device setup to send to the TD panel.
    please also double check the IP is the panel and not the frame.
    in dashboard there is a debug view and yes you can attach debug messages to run after your events.
  • 5.  RE: Custom Control to send GPI
    Posted 06-11-2026 11:24
    Hi Les, I got it! I set the device IP to the panel because I am running the dashboard panel off my frame.
    Jason Sanford
    Broadcast Engineer
  • 6.  RE: Custom Control to send GPI
    Posted 06-11-2026 11:27
    You can't run the panels off the frame. They run on the panel or on an external pc.
    To clarify you are good and it's working now?
    Plane is about to push back so won't be able to respond for some time.
