Hello, i have the xpression setting up with 2 NDI outpus 1920x1080
Can i setup one of the outputs with a custom resolution?
NDI outputs get their resolution from loaded project settings, so you wouldn't be able to set up different resolutions per output, but the resolutions can change between project loads if needed.
62 Auriga DriveNepean, OntarioCanada, K2E 7W6
Phone+1 613 228-0688Emailcommunity@rossvideo.com
LoginJoinHelp/FAQEventsrossvideo.com
Terms and ConditionsPrivacy PolicyDMCA Policy
