The ID is just an identifier number, it doesnt have to match anything nor do you need to create a panel.
It will be the number that identifies the button in the asrun logs when you are looking at who exectued which crosspoint.
Mike Pomerleau
Sent: 07-08-2025 08:28
Subject: Custom panel for simple crosspoint control
Hi Mike,
Thanks for the info. I'm looking to create a set of custom buttons rather than use the standard panels so I've tried the Rosstalk option but I'm now struggling with the user_id. Is this the Panel_ID of the Ultritouch panel that the custom panel will be used on or do I need to create a new ID for the custom panel?
Thanks,
Gareth
Gareth Davies
Support Engineer
ITV Plc
Sent: 07-07-2025 17:49
Hi Gareth,
There is a slightly easer way of creating panels if you use the panel builder and select the ultritouch as the template you want to use.
See the Ultritouch user guide on page 26 (configure a Crosspoint button)
If you want to create your own custom buttons, you can also use Rostalk as an option for crosspoint control.
XPT D:<dest> S: I:<user_id> [L:<levels>]</levels></user_id></dest>
There is an example on page 84 here.
Hope this helps!
Mike Pomerleau
