The syntax/code that Aury has provided will perform the functions of the panel but it sounds like you need to create the layout of the buttons for the operation side, this is OGLML section that dictates where buttons are on the panel. Can you share your ideas on a panel layout?
Sent: 07-18-2024 15:08
Subject: Custom Panel to control Ultrix
Hi Andrew,
It is a combination of OGLML and OgScript. You can go in edit mode and use the source tab to enter it.
Here are the steps on how to:
- Create a new custom panel by choosing File > New > New CustomPanel File
- The new custom panel will load, click on PanelBuilder Edit Mode
- Double click inside the panel, and click on the Source tab.
Thank you,
Aury Rukazana
Senior Software Developer
Sent: 07-17-2024 15:38
Hi Aury,
I am hoping to accomplish the same thing as Dalot. Where do I enter in the code that you provided to program a custom panel? Is that ogScript?
Andrew
Andrew Morgan
Operations
CBS News
Sent: 02-01-2024 11:59
Hi Dalot,
Assuming that you want to set a Crosspoint, please find below a sample custom panel source code on how to achieve it.
In the source code below, we have two params displayed as combo choices.
The first param stores the source and the second param stores the destination. To populate the combo box choices (int choices), we use the loadUltrixTable function. You can use the (CTRL + I) shortchut key to inspect the values, by double-clicking the dropdowns which should match available sources of your ultrix.
The most important function you are probably looking for is the doUltrixSwitch, which is the one used by the take button. In this scenario, the doUltrixSwitch creates a multiset to update all levels you wish to update using the relevant oid, and executes it.
I have created a second doUltrixSwitch function which uses rosstalk commands to achieve the same thing, the code snippet will be added below the first one.
<abs contexttype="opengear" gridsize="20" keepalive="true"> <meta> <params> <param access="1" constrainttype="INT_CHOICE" name="Sources" oid="Sources" precision="0" stateless="true" type="INT32" value="0" widget="combo"> <constraint key="0">Nothing</constraint> </param> <param access="1" constrainttype="INT_CHOICE" name="Destinations" oid="Destinations" precision="0" stateless="true" type="INT32" value="0" widget="combo"> <constraint key="0">Nothing</constraint> </param> </params> <ogscript handles="onload">function loadUltrixTable(sources) { var uOid = sources ? 'params.sources' : 'params.dests'; var pOid = sources ? 'Sources' : 'Destinations'; var newValues = []; var numValuesP = params.getParam('ultrix', 'params.sources', 0); var numValues = 0; if (numValuesP != null) { numValues = numValuesP.getElementCount(); } for (var i = 0; i < numValues; i++) { var name = params.getParam('ultrix', uOid + '.' + i + '.name', 0).getValue(); newValues[i] = { "key": i, "value": name }; } if (newValues.length == 0) { newValues.push({"key": 0, "value": "Nothing Found"}); } params.replaceConstraint(pOid, params.createIntChoiceConstraint(newValues)); } function loadUltrixInfo() { loadUltrixTable(true); loadUltrixTable(false); } loadUltrixInfo();</ogscript> <api>function doUltrixSwitch(context, source, destination, level_string) { level_string = level_string + ""; level_string = level_string.replace(/\s/g, ' '); var levels = level_string.split(","); var multiset = params.createMultiSet(context); for(i=0; i<levels.length; i++) { multiset.setValue("params.statusByDestination." + destination + ".inputstatus", (levels[i] - 1), source); } multiset.execute(); }</api> </meta> <param expand="true" height="60" left="80" oid="Sources" top="100" width="280"/> <param expand="true" height="60" left="80" oid="Destinations" showlabel="false" top="40" width="280"/> <button buttontype="push" height="120" left="360" name="Take" top="40" width="200"> <task tasktype="ogscript">doUltrixSwitch("ultrix", params.getValue('Sources', 0), params.getValue('Destinations', 0), "1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17")</task> </button> <simplegrid contexttype="opengear" height="40" id="ultrix" left="80" objectid="UltricoreBCS-TLO-0000-C8931<br>Slot 0<br>UltricoreBCS" objecttype="UltricoreBCS" rows="1" top="180" width="480"> <param element="0" expand="true" oid="0x105" showlabel="false" widget="1"/> </simplegrid></abs>
function doUltrixSwitch(source, destination, level_string) { ultrixIP = "yourIP or domain name"; var ultrixRossTalkPort = 7788; var newDestination = parseInt(destination) + 1; var newSource = parseInt(source) + 1; var rossTalkCommand = "XPT D:" + newDestination + " S:" + newSource + " I:7 L:" + level_string; rosstalk.sendMessage(ultrixIP, ultrixRossTalkPort, rossTalkCommand);}
Hope this helps!
You can also find documentation on supported rosstalk commands here.
Aury R.
Aury Rukazana
