Hi Casper,
Your best bet is to give technical support a call and go through the setup with them.
It looks like you may not have the Dante sources and destinations added to your dataabse.
The Ultrix userguide explains how to do this starting on page 209 Here
Audio Routing Overview Once Ultrimix-Dante is configured, and connections are made via the Dante Controller, you can route the audio channels via the Ultrix database. This is done like any other routing on Ultrix as follows:
• The Dante audio channels are made available via AUX C.
• The AUX B audio channels will not be available while Dante channels are in use.
• This will be reflected by an addition of AUX C channels for SOURCES and DESTS in the Ultrix database and issuing take errors for AUX B connections when Ultrimix-Dante is enabled.
Mike Pomerleau
