We've now got a working query! Thank you very much for all the assistance.
ogscript.asyncHTTP("http://172.23.5.201/graphql", "POST", {'api_key': 'apikey', 'Content-Type': 'application/json'}, query1, callback, true);
Using the correctly formatted asyncHTTP command I am now attempting to make crosspoint changes on dante devices (through a dante domain) with a custom dashboard panel on an Ultritouch panel - very exciting!
Thank you once again for all your assistance.
Sent: 03-18-2024 10:41
Subject: Dashboard asyncPost to GraphQL Apollo Server
Hi Syed
The header fields argument replaces the content-type argument so you will need to manually add the content-type header yourself:
ogscript.asyncHTTP("http://172.23.5.201/graphql", "POST", {'api_key': 'apikey', 'Content-Type': 'application/json'} , queryTest3, callback, true);
James Peltzer
Sent: 03-17-2024 19:32
Hey James,
Thank you for the response. We've been slowly working through this issue in the background and have an update for you.
This is our current script returning a 200 error message from the server. (Good news, we're in the right place.)
ogscript.debug("1");
function callback (result){
ogscript.debug(ogscript.jsonToString(result));
queryTest = {"query":"query {Domains { domains { name status { clocking connectivity latency subscriptions summary } }}"};
queryTest2 = {"query":"query { __typename }"};
queryTest3 = {"query": "query Domains {domains {name status{clocking connectivity latency subscriptions summary}}}"};
apikey = {'api_key':'OUR-API-KEY-HERE' };
ogscript.asyncHTTP("http://172.23.5.201/graphql", "POST", 'application/json', queryTest3, callback, true);
ogscript.debug("2");
The debug window showing the 200 error due to the lack of authentication:
11:54:55:372: 1
11:54:55:380: 2
11:54:55:390: {"responseCode":200,"contentType":"application/json; charset=utf-8","url":"http://172.23.5.201/graphql","value":"{\u0022errors\u0022:[{\u0022message\u0022:\u0022Unauthenticated user or user not found\u0022,\u0022locations\u0022:[{\u0022line\u0022:1,\u0022column\u0022:16}],\u0022path\u0022:[\u0022domains\u0022],\u0022extensions\u0022:{\u0022code\u0022:\u0022UNAUTHENTICATED\u0022}}],\u0022data\u0022:null}\n","bytes":[123,34,101,114,114,111,114,115,34,58,91,123,34,109,101,115,115,97,103,101,34,58,34,85,110,97,117,116,104,101,110,116,105,99,97,116,101,100,32,117,115,101,114,32,111,114,32,117,115,101,114,32,110,111,116,32,102,111,117,110,100,34,44,34,108,111,99,97,116,105,111,110,115,34,58,91,123,34,108,105,110,101,34,58,49,44,34,99,111,108,117,109,110,34,58,49,54,125,93,44,34,112,97,116,104,34,58,91,34,100,111,109,97,105,110,115,34,93,44,34,101,120,116,101,110,115,105,111,110,115,34,58,123,34,99,111,100,101,34,58,34,85,78,65,85,84,72,69,78,84,73,67,65,84,69,68,34,125,125,93,44,34,100,97,116,97,34,58,110,117,108,108,125,10]}
Now this script below is the exact same but including the insertion of the authentication header in your post:
apikey = {'api_key':'OUR-API-KEY-HERE'};
ogscript.asyncHTTP("http://172.23.5.201/graphql", "POST", {'api_key': 'apikey'}, 'application/json', queryTest3, callback, true);
Here is what the debug window shows (I have highlighted the important area in bold):
12:02:56:421: 1
12:02:56:432: OGScript exception in script named >>>anonymousLabelTask<<< with content
function thisIsTheDashBoardReservedFunctionName() {
/********* The line above was added by DashBoard because ogScript tasks are functions. *********/
Here our script is just printed out as it is above..
/********* The lines below were added by DashBoard because ogScript tasks are functions. *********/
// This is the end of the ogScript
EXCEPTION MESSAGE:
org.mozilla.javascript.EvaluatorException: Can't find method com.rossvideo.common.oglml.ogscript.AbstractOGScriptCommands.asyncHTTP(string,string,object,string,object,function,boolean). (anonymousLabelTask#18)
and more org.mozilla.javascript runtime reports.. quite a few.
I'm under the impression that by adding the authentication header for the api key we invalidate the expected fields in how asyncHTTP is as a command.
We have successfully queried the graphQL server using powershell with the data in queryTest3 as well as the api key to make sure what we are trying to send is correct. We are attempting to do the same in dashboard now.
Is there a way to include the authentication header without invalidating the content type field? We have tried the queryTest3 object before and after the content type field as well.
Thank you for your eyes on this,
Syed Abbas
Solution Architect
Gencom Technologies
Sent: 01-04-2024 09:39
Hi Syed
The posted snippet should work provided a) The server will accept HTTP POST messages as opposed to just HTTP GET messages and that it allows the API KEY authentication to be sent as part of the QUERY STRING as opposed to part of the HTTP HEADERS.
If your server is expecting the key as part of the headers, you will need to use ogscript.asyncHTTP to inject the new header fields:
ogscript.asyncHTTP("http://172 * * */graphql", "POST", {'api_key': 'examplekey'}, queryTest, null, true);
You should also check the casing (uppercase/lowercase/mixed) of the field names to make sure you are sending what the server is expecting.
James Peltzer
