Hi there
You can use Visual Logic to trigger a scene director. You will need to send a 1 to trigger the scene director to play (a Boolean will also work). Connect a text field (with either a 1 or 0) value to the Scene Director's Play Action. Then you'll need to trigger the 1 somehow, most likely a Button.
Hope that helps?
Cheers., Ilana
Ilana Gordon
Sent: 11-04-2025 15:10
Subject: Dashboard commands for Scene Directors
Update, I'm currently using Dashboard to send GPI to xpression and the GPI triggers the scene director. Seems to work, but would still be nice to Dashboard to send direct.
Hamelth Villalobos
Los Angeles United States
