Hey Garner, Jeff,
I'm almost finished with my panel...just looking at things to make it more user friendly.
Since the director might be focused on the panel sometimes, I thought using NDI to display my program and preview would be good.
Have you found SDI-NDI converters that are better suited to this?
I have also considered taking my Remote Sequencer display of five individual channel sequences across a two 16x9 monitors and rearranging them into ten NDI windows across two 1920x540 monitors---channel 1 preview, sequence, channel 2 preview, and so on.
Will HDMI-NDI converters support this approach?
Thanks,
James.
James Hessler
WAAY TV (ALLEN MEDIA BROADCASTING)
Sent: 10-11-2024 14:03
Subject: Dashboard Controlling Xpression Remote Sequencer
Here's what valid RemSeq RossTalk commands look like in Docklight scripting:
The command were added in v9 or early v10, so you should be ok.
Make sure you have the RossTalk GPI board setup in RemSeq (RemSeq > File > Hardware Setup > GPI Boards > RossTalk
Make sure the RossTalk board is using a different port number than any other software also install in the same PC. (Ex set Dashboard and RemSeq to use port 7790 for RossTalk).
Sent: 10-10-2024 22:56
Hey Garner!
While I've been able to send the down command for the main sequence, I haven't been able to send the channel specific commands. Are the commands above still valid?
Thanks,
James.
James Hessler
Sent: 02-21-2024 13:47
Here are the RossTalk commands that are specific to Remote Sequencer control. You will need to add the RossTalk board in the RemSeq preferences:
UP
DOWN
READ
NEXT
NEXTSTORY
PREVSTORY
CLRA
SWAP
CHANDOWN [chan]
CHANUP [chan]
CHANREAD [chan]
CHANNEXT [chan]
CHANCUE [chan]
CHANTAKEOFFLINE [chan]
CUE [id]
SEQO [id]
SEQI [id]
TAKE [id]
FOCUS [id]
FOCUSSTORY [roid:storyid]
Sent: 02-20-2024 09:53
Xpression Version 10.0 build 5272
Sent: 2/20/2024 9:48:00 AM
Subject: RE: Dashboard Controlling Xpression Remote Sequencer
What version and build of XPression are you running?
