The bonus bit in the example is that the browser is set to the current value of the URL parameter when it is created by using:
<browser bottom="5" id="browser" left="5" right="5" top="50" url="%value['URL'][0]%"/>
James Peltzer
Sent: 04-21-2025 11:19
Subject: Dashboard Custom Panel with buttons to change the content of a Browser component
Hi Martin
Yes, it is possible to do this with a small piece of ogScript:
ogscript.getComponentsById('ID_OF_BROWSER_CONTROL')[0].setUrl('URL_GOES_HERE');Here it is in an example:
<meta>
<params>
<param access="1" constraintstrict="false" constrainttype="STRING_STRING_CHOICE" maxlength="0" name="URL" oid="URL" type="STRING" value="http://www.google.ca" widget="radio-toggle">
<constraint key="http://www.google.ca">Google</constraint>
<constraint key="http://www.cbc.ca">CBC</constraint>
<constraint key="http://www.canada.ca">Canada</constraint>
</param>
</params>
</meta>
<param expand="true" height="36" left="5" oid="URL" right="5" top="5">
<task tasktype="ogscript">ogscript.getComponentsById('browser')[0].setUrl(params.getValue('URL', 0));</task>
</param>
James Peltzer
