Hi Max,
This is a known issue regarding version 9.9.1 and 'Send TCP Messages (String)' 's underlying rosstalk.sendMessages() ogScript command.
The issue has been resolved in 9.10, which is releasing within a week.
In the meantime, if you replace the existing ogScript command to be
rosstalk.sendMessage("localhost", 5250, [your message here]);
rather than
rosstalk.sendMessage("localhost", 5250, [your message here], null);
as it was previously, this will resolve your issue on 9.9.1 and allow you to send messages to the CasparCG server.
Michael Quach
Sent: 05-08-2024 11:26
Subject: Dashboard isn't sending TCP Messages
It simply was a visual logic Send TCP Messages with 127.0.0.1 as IP, 5250 as port and the string I wanted to send (a play command).
Downloaded Dashboard today so 9.9.1
Thanks,
Max
Max Rouard
Sent: 05-08-2024 11:22
Hi Max,
Would you be able to post the ogScript being used to send the TCP message, as well as the DashBoard version where you've experienced this issue?
Thanks,
Michael Quach
