The tab container was just a method to have one page with either/or panel displayed. If you want both up on a single Custom Panel, that can be done as well.
Alun Fryer
Technical Marketing Lead, Hyperconverged Solutions
Sent: 07-24-2026 07:25
Subject: Dashboard - Launching Panels for Production
Thank you. That gave me what I needed. Curious on why I need the tab container. I tried with it and without. Seems to work both ways.
Regardless, thank you.
Robert Kinnan
Broadcast Engineer
Spectrum Charter News
Sent: 07-23-2026 14:59
You can create a custom panel and put a Tab container in it. Then drag the desired panel to each tab and insert the embedded editor. User then opens the custom panel and navigates to the desired panel.
Alun Fryer
Sent: 07-23-2026 12:09
Need to go in a different direction. I've created a custom dashboard with two buttons. I want these buttons to trigger, basically a click or link, to an existing panel to open it. If I view the established panel, it gives me multiple ways to ID it. I just can't remember any of the logic to make that happen.
Robert Kinnan
Broadcast Engineer
Sent: 07-23-2026 08:50
Robert,
it can be done. I inherited a system that did just that. On boot it opened an entire set of custom panels. Sorry I can't give you step by step instructions because I didn't build it.
But it is definitely possible.
Paul Whitfield
Nashville United States
