Hello Rich,
Using the file picker opens very fast on my computer. I would suggest trying on a different computer.
You can create a task on the file picker parameter which will get invoked once the user closes the picker. I recommend using the Visual Logic editor to create your task. Here is a simple example of a panel which has a picker and text field to display the first line of the selected file.
<meta>
<params>
<param access="1" maxlength="0" name="selectedFile" oid="selectedFile" type="STRING" value="" widget="file-picker"/>
<param access="1" maxlength="0" name="firstLine" oid="firstLine" type="STRING" value="" widget="default"/>
</params>
</meta>
<param expand="true" height="36" left="21" oid="selectedFile" showlabel="false" top="20" width="408">
<task tasktype="ogscript">/*! block id=1006,1003,1002,1000 !*/
params.setValue('firstLine', 0, ogscript.createFileInput(params.getValue('selectedFile', 0)).readLine());
<block id="1006" type="param__top&amp;firstLine (firstLine)[0]" x="837" y="116" w="243" SET="ID:1003" />
<block id="1003" type="file_readLine" x="566" y="118" w="243" FILEID="ID:1002" />
<block id="1002" type="ogscript_openfileread" x="342" y="118" w="243" PATH="ID:1000" />
<block id="1000" type="param__top&amp;selectedFile (selectedFile)[0]" x="104" y="115" w="243" SET="" />
/*!!<checksum>6363f78e8f281b78e70034f5af98d847</checksum>!!*/</task>
</param>
<param expand="true" height="46" left="23" oid="firstLine" top="64" width="1200"/>
Hope this helps,
Marc-André Parent
Sent: 08-25-2023 12:15
Subject: Dashboard open/save file dialogs?
I did eventually get a file picker working, but it's VERY slow to open – at least on this machine – I still need to try it on some other ones and see if the problem persists. Turns out it was pretty easy:
<param expand="true" height="40" left="33" oid="filename" top="28" widget="file-picker" width="606"/>
Set the widget to "file-picker" and we're done. Well, almost... I would like to have a function get called when I select a file or folder and close the file picker. Right now I have a separate button the user has to hit manually to process the file. I kinda gave up on chasing down if having a callback function was possible since it was just sooooo slow to get the dialog box open, it wasn't going to be usable in a real production environment. I'm still in the "I don't really know what I'm doing yet" stage though, so I freely admit I could be doing something horribly wrong. J
Sent: 8/24/2023 4:41:00 PM
Subject: RE: Dashboard open/save file dialogs?
Hello Rich,
sorry for the delay. Can you expand on the use-case you are trying to execute? What 'data' do you want to load from/save to file?
Regards,
Marc-André Parent
