I designed the attached panel for our church setup. We have 6 cameras (5 PTZ) and as you can see, controls for all 6 are on this panel-cameras 5 & 6 are not used as much so I put them on two tabs on the right to save real estate. Cameras 1 thru 3 are our main camera shots and camera 4 (which is in the drawer to the left) is our manned "follow-cam" (a Canon XF405) and that drawer contains LAN controls for exposure, focus, white balance, etc. The drawer on the right contains controls for room shades, advancing slides in ProPresenter, switching lighting cues and other actions.
Last night, we had our "Blue Christmas" worship service and it is conducted in low light conditions. There are a few other services during the year that are offered in the evening and again, similar low-light conditions are used. I'm wondering if something is possible. Since I save exposure/gain with my presets, I would like to either create another panel that would have the shotboxes access Bank2 for each of the cameras or, ideally, add a button that would select either Bank 1 or Bank 2 on the same panel. Obviously, I would need to ensure that the proper panel is initially loaded if we go with the first option. By the way, I have not yet set up or used Bank 2-would I reference shots starting with #1 or #65?
How would I go about creating the code to make this happen and which would be easier, a separate panel for low-light conditions or some sort of switch (button selector) to change my existing shotboxes to target Bank 2?
I also included the source code for the panel I created in the attachments.
Steve Witwicki
Video Technical Director
Light of Christ Church
