You can set dashboard to stream its data.
then setup a new datalinq
then in config choose XML tree
then it will look like XML data tree in xpression
Sent: 04-21-2024 09:56
Subject: Dashboard parameter export to xml
Hi everyone
I have a dashboard that is set as an Internal data source, so it streams directly to XPression.
On our last production, there was a parallel graphics system (v-mix) that was doing the big screen. He was doing his own running clocks which were mostly not in sync with our official timer. I wanted to know if it's possible to export parameters in real time as an xml file (or other), so that another system can pull that data in and display it?
Cheers
Ilana
Ilana Gordon
